68 dart fender help?
I finally got around to stripping my front end off my dart, and a while ago I bought a fiberglass front end for it (fenders,hood) new from a company that I found online. But I set the fenders up on the car and they don't look like they will work, they are missing the dish where the headlight sits and back by the door it doesn't sit right. Also the hood came with smaller springs for the hood hinge, and im going to have to grind alot to make them work. Has any one had experiance changing over to fiberglass? a
Guest
Posts: n/a
Nobody makes full replacement fenders yet. Patch panels or good used is all you can do. You can contact http://www.autometaldirect.com/ to see if they will in the future
Guest
Posts: n/a
ive worked with fiberglass parts quite a bit.(and make my own fg stuff) and it dont matter even high dollor "vis racing" you got drill, apply heat to bend, grind. fix the cracks they come with. pain in the butt. but after 6 hrs on one fender your ready to primer and paint
looks like to me they are missing the headlight bracket which usually comes with the dart fb fender if you ask for them when ordering but you might want to call the place you got them from and ask if they have the bracket ,, but fiberglass is easy to work with so you should be able to make them work for you but you could just need to sand the door edge a bit and line it up to fit right with body washers and such but i would try before you try and find some other fenders as they are hard to come by
67rockabillydart
Dec 25, 2012 11:18 PM
70DartMike
Nov 17, 2012 02:58 PM
1966DartConvertible
Jul 30, 2010 06:43 AM
