70s motor home 413 engine worth much?
Old Oct 20, 2009 | 06:23 PM
mopsled's Avatar
Junior Member
I found a 413 engine inside a motor home in a bone yard, still had the air cleaner on it which said 413, 265 horsepower. I was curious what if any the engine might be worth if I sold it as a rebuild which I am sure would be the case. Engine is complete from thremoquad to pan.
Thanks for any estimates.
Old Oct 21, 2009 | 03:55 PM
people would want the block
Old Oct 22, 2009 | 03:18 AM
Plus the trannies are stronger than the ones found in the cars. You wouldn't make your money back if that is what you are wondering though, at least not in today's market unless you own your own machine/engine rebuilding shop.
Old Oct 22, 2009 | 12:42 PM
rr69half6bbl's Avatar
no, unless you can get it for like 2 bills, then maybe sell it for 450-500, but thats about it, not a big market for them. not like 440`s.If you have a project yourself, and dont mind its a 413 and not a 440, its a great motor to build, just not as desireable.
Old Oct 23, 2009 | 03:49 AM
Now those are the RB motors of the big blocks though correct? So if you had a 383 or a 400, you could use some of the parts to build your own stroker..... I could be mistaken though.
Old Oct 23, 2009 | 10:40 AM
yes tim, the 413 `s and early 426 wedges were rb`s. yes you can use the crank in a 383,400 and stroke them.
Old Oct 23, 2009 | 11:25 AM
rdrunner1974's Avatar
RV 413"s
It may have a gear driven cam which in turn will cause the cam to turn in the oposite direction. With that, there may be an odd distributor which uses an adapter. These are low compression engines. 383-400 water pumps, heads and a few other components will interchange. About all RB parts will fit--cams, heads, distributor (cam must be changed to use dist.) oil pump
If the trannie has the drum brake, you can change the output shaft and tail housing. It is stronger as Tim said.
Old Oct 23, 2009 | 06:53 PM
i also believe that they dont have forged cranks in them, so that makes them less desirable
Old May 10, 2023 | 08:25 PM
Rich2844's Avatar
I believe most had forged cranks, I know my 72 motor home does. It had the gear driven cam, which I got rid of putting a timing chain and gears in there place with a different cam. The trans doesn't have the brake drum park on it but it has a bolt on yoke bolted to the output shaft. So that will have to be changed.
Old May 10, 2023 | 09:06 PM
413s have forged Kranks play, has the same rod length as a 440. The problem is pistons, all off the shelf pistons are low compression so custom aftermarket pistons will need to be sourced. $$$$
Old May 11, 2023 | 05:21 AM
Kuvasz101's Avatar
70s 413 with a thermoquad? I thought they stopped making the 413s in the early 60s. Thermoquads were on the 340, 360 and 400 mid 70s smogger engines. I think I'd check some casting numbers, it's not pointing to a 413. Maybe it was a special made 413 for motorhomes.
Old May 11, 2023 | 06:00 PM
The 413 was used until the early 70s in motor homes…
Jake440
Feb 1, 2015 01:36 PM
Buffalojoe426
May 14, 2010 03:42 AM
xynicgreven
Jul 28, 2009 05:42 PM
xynicgreven
Jun 19, 2009 10:27 PM
mopar nate
Oct 29, 2008 04:45 AM
