727 torque flite transmission
Old Jul 24, 2011 | 11:43 AM
Coronet Tom's Avatar
I have a leak in the plug/fitting at the front of the transmission above the cooling line . When I attempt to remove the fitting/plug I am unable to get it loosened , however when I loosened the 3/4 outer fitting it seems like it may be a locking device and the square plug/fitting is an adjustment . I am afraid to remove it and may have already changed the adjustment ...any suggestions about what may be happening here would be appreciated . I want to teflon the threads to stop the leak .
Old Jul 24, 2011 | 01:34 PM
That is the kickdown band adjustment. Tighten the inner "bolt" to 72 in lbs then back out 2-2 1/2 turns and tighten outer "nut" to 30 in lbs. The amount of back out will vary based on year and vehicle so the proper manual should be referenced. There is no seal on the adjusting screw but you can put a dab of silcone under the locking nut.
Old Jul 25, 2011 | 10:27 AM
many thanks
Hi Coronet 500
thanks for the information , another question ..any idea how to get a free manual for the torque flite 727 transmission?
Tom
Old Jul 25, 2011 | 11:22 AM
John Van's Avatar
Tom,here's a good post about the 727 tranny:
http://www.allpar.com/mopar/transmis...-tom-hand.html
john
Old Jul 25, 2011 | 06:01 PM
Well I don't know about free but HP Books has a good one by Carl H. Munroe. The band adjustment should be in just about any vehicle specific manual.
This is how it is suppose to work, a guy asks a question a guy gets an answer.
Some of those Furd forums I look at for my son you ask then get "why do you want
to do that bla bla bla". Mopar guys are the best, keep asking someone will give you
a prompt correct answer without all the B.S..
Old Jan 26, 2012 | 08:50 AM
bobbyd173rd's Avatar
What do you guys think of the tci super street fighter tranny
Old Jan 26, 2012 | 01:09 PM
Depending on how much you turned it ? If you have any problems adjusting it ? You may have to remove the pan. It is possible for the strut to fall out of position
66Barracuda
Jul 31, 2012 04:08 PM
Justin Ward
Jun 26, 2012 09:46 AM
Barfly
Mar 21, 2011 03:25 PM
jdewoskin
Aug 7, 2010 02:14 PM
blindman
Apr 16, 2007 02:02 PM
