727 tranny
Old Dec 23, 2011 | 12:07 PM
willysman69's Avatar
727 tranny
Can anybody tell me how to find out what year my 727 is rumor is it came out of 68 but I would like to find some numbers on tranny to verify.Thanks
Old Dec 23, 2011 | 10:11 PM
Good question. The only way I know of is if you have the valve body out It should have a star within a circle with a year date cast in it...
Old Dec 24, 2011 | 06:02 AM
Along the driver's side pan rail there is a stamped number, in the number is the date code. After '68 they added a pad, just above which has VIN stamped to it. Post up your pan rail number and we'll give it a go.
Old Dec 29, 2011 | 02:54 PM
ok the numbers i found are k368105443782197 thanks for any help
Old Dec 29, 2011 | 04:01 PM
If the 4378 number has a space on either side then I have it as June 1973.
mr340's Avatar
Are there spaces or dashes between the numbers? If so, where are they. The date code is a 4 digit number. 2197 converts to 8-3-67
Old Dec 29, 2011 | 06:01 PM
yes there is spacing between the 4378 and the rest of the numbers. are these ok transmissions thanks
Old Dec 29, 2011 | 06:35 PM
There were some minor improvements made after 1970 but a 727 is a good tough transmission. Improve it to match your power and planned useage, stock ones will take alot of torque.
Old Dec 30, 2011 | 05:14 PM
now im really confused there are spaces between some of the numbers and was thoght to have a 73 with the 4378 number
Old Dec 30, 2011 | 07:23 PM
That long number should be in three groupings, the center or second group (4 digit) number will be the date code based on the chrysler 10,000 day calender.
Old Dec 31, 2011 | 05:31 AM
mr340's Avatar
Forget what I said, Coronet 500 is correct, and you could have found this out with a simple google search.
Valex9499
Apr 4, 2010 08:55 AM
HemiSilva
Sep 17, 2009 04:49 AM
80VDuster
Aug 24, 2008 09:56 PM
Mixmastermerrill
Jul 29, 2008 10:45 PM
alwaysamopar
Jul 11, 2008 01:33 AM
