727 trans
Old Mar 15, 2020 | 06:12 AM
JPR56's Avatar
727 trans
hey Guys, need your help. Had my 727 trans rebuilt about a year ago. Changed the neutral safety switch which was leaking.got the oil level correct but car will only go into reverse, no first second or third gear. Any suggestions
Thanks Again
Old Mar 15, 2020 | 08:06 AM
You check the fluid level while in Neutral correct?
Old Mar 15, 2020 | 12:15 PM
JPR56's Avatar
Yes
Old Mar 16, 2020 | 08:05 AM
If the linkage is all good in that case.... I would say you had a rear Drum Failure or a seal went bad....
Old Mar 16, 2020 | 04:22 PM
fivepoint's Avatar
Did it work ok before you changed the switch? Does the selector move into the drive position?
Old Mar 16, 2020 | 07:59 PM
Pull the switch and put the old one back in and see if it works....
inri
Aug 25, 2019 07:21 AM
Miradamike
Nov 4, 2018 07:56 AM
droptail
Jul 23, 2018 08:34 PM
JPR56
Apr 19, 2017 06:11 PM
anthony oborny
Jan 10, 2010 06:06 PM
