8 3/4 rear end
Old Sep 10, 2010 | 05:26 PM
69POLARA383's Avatar
8 3/4 rear end
Newb question... have a 8 3/4 rear end came stock on 69 polara 383, are all 8 3/4's sure grip? or do I have to go find one or get it rebuilt?? Thanks.
Old Sep 10, 2010 | 05:28 PM
This work?
http://www.justdifferentials.com/ind...oducts_id=1599
Any thoughts?
Old Sep 10, 2010 | 05:30 PM
drgrcr74's Avatar
If I am not mistaken, sure grip refers to the center section, and not all 8 3/4's are sure grips. Some had open differentials. You can test this some how...but I have been in drag racing too long, where everything has a spool. Some one will correct me but I think if you spin one wheel if the other turns in the opposite direction, it is a sure grip. "He said crossing his fingers, and hoping he is right!"
Old Sep 10, 2010 | 07:36 PM
Silverick's Avatar
No. All 8 3/4's are not sure grip.
Old Sep 10, 2010 | 08:04 PM
scotts74birds's Avatar
Sorry, a sure-grip or "posi" will turn both wheels in the SAME direction. An open rear end will turn them in opposite directions
Old Sep 10, 2010 | 08:40 PM
Silverick's Avatar
The cool part about an 8 3/4, is that if you can find a Sure Grip center section.... it's a fairly simple task to swap them out. I did this once and bought a complete rear end from a '68 Roadrunner to put in my first C body.... Wrong! Had it all cleaned and painted up but, I hadn't measured the overall length and the C body axles are longer. So, I ended up swapping the 3rd member and everything worked great.
Old Sep 10, 2010 | 09:20 PM
blue 68 gts's Avatar
Seen plenty of 8 3/4 with opens.
A, B, C, E and truck 8 3/4s are all different lengths. A bodies have the shortest.
72_coronet
Jan 12, 2009 05:57 PM
smackhonda
Jun 5, 2008 10:50 AM
killermopar
May 4, 2008 10:47 AM
thekinzuakid247
Apr 3, 2007 07:37 AM
thekinzuakid247
Mar 25, 2007 01:56 PM
