89 dodge truck starts but dies after awhile
Old Dec 6, 2015 | 07:32 PM
rgengelking's Avatar
i have a 1989 dodge truck, it will start and run but when it starts to warm up the idle will start to drop off and then die. I have replaced the throttle position sensor,mar sensor, injectors, 02 sensor,fuel regulator, and new plugs, can it be electric if you can help thankyou
Old Dec 8, 2015 | 02:03 PM
I would start by hooking up a fuel pressure gauge To see what happens when it quits. then check for spark when it quits... Does it have an idle speed sensor at the back of the throttle
Old Jan 2, 2016 | 03:42 AM
crwchf16's Avatar
I have a 1989 W-150 as well and ran into this exact issue. if you turn it off does it start right back up and run for a few minutes before it quits again? If so then I agree with TVLynn, this sounds like your fuel pump is starting to go. How does it idle?
Johnny2stroke
Dec 27, 2011 04:42 PM
Jbalz
Sep 29, 2011 08:35 AM
dodgenut7
May 10, 2011 03:55 PM
deadkelly
Oct 4, 2010 04:14 AM
Feb 24, 2010 01:44 PM
