Old Feb 10, 2010 | 07:52 PM
dingo's Avatar
Junior Member
Has any one put a 360 into a fox body mustang? I use the mustang for racing and tired of breaking the trans. Or is there a bell housing that i can put on a 727 trans. Need some input. I do have a 5.9L magnum motor and a 727. Just wanted to see if any of you have done this or seen any one do this. Really dont want to cut up the car. The reason I using a ford is because it weighs 2500 pounds right now.
thanks
Old Feb 10, 2010 | 11:13 PM
theomahamoparguy's Avatar
I've actually seen this done in a mag, (Hot Rod I think). Tons of room in the fox mustang for the motor, tranny might be a different story if thinking 727.
Ultrabell might make the bell adaptor. Google Ultra bell.
Old Feb 11, 2010 | 05:38 AM
62Furious's Avatar
sacrilege do not like cross breads
Old Feb 11, 2010 | 12:23 PM
mopardrt's Avatar
you should have read the topic about the guy putting the BB chevy into the dart swinger..... what ever happened to that guy?
Old Feb 11, 2010 | 03:06 PM
volaredon's Avatar
Member
I have a Shivvy 3/4 ton that is taking up my garage as we speak, waiting for the owner to come up with this "crate motor" for over a week now; tomorrow= a week since I pulled the old engine; meaning taht if MY shyt breaks I'm working on my own OUTSIDE in 20* temps. If he drags **** much longer on coming up with this engine, I have a 318 and 727 that will find its way in there to get the thing OUTTA HERE with. That said 350s are actually good for something; weight in my truck over the rear axle so I can drive it thru this winter slop! (with a 318 and 4 barrel under the hood)
Old Feb 11, 2010 | 08:53 PM
dingo's Avatar
Junior Member
do you know if there any links that i see pics at? does anyone know what the demetions are hight, width, and length?
Old Feb 11, 2010 | 10:05 PM
dont have a link but here are some general measurements for a stock engine;
width of outside dimension of valve cover to valvecover: 20.5"
top of carb to bottom of pan (stock engine): 28"
mounting flange for fan to back of block: 23.5"
total width; outside measurement of exhaust manifolds: 25"
top of valve cover breather to bottom of oil pan: 29.5"
weight of engine: 550 lbs.
starter location: left side
oil pan configuration: center or rear
Old Feb 11, 2010 | 10:29 PM
dingo's Avatar
Junior Member
thanks
