air conditioning
Old Mar 16, 2009 | 03:21 PM
sgp7679's Avatar
Question air conditioning
I just put the belt on my ac compressor and now my ac works good and cold. The only thing is only the top vents on the dash blow and the bottom ones under the dash dont blow anything. What could cause that? Also my i press heat and the air dosent get hot. What could that be?
Old Mar 16, 2009 | 06:38 PM
Crazy4Carz.Com's Avatar
There is a vacuum valve that opens and closes the damper under the dash. Could be a broken/missing vacuum hose.
Old Mar 18, 2009 | 11:07 PM
rr69half6bbl's Avatar
Or you have a mouse nest catching the air door so it wont shut and block off the ac side from the heater side.
Old Mar 19, 2009 | 07:02 AM
72RDRNR's Avatar
As for it not blowing hot, have you checked to make sure the temp lever is hooked up on the backside?
dnlwstwd
Jan 2, 2015 02:29 PM
jkotis
Sep 20, 2013 03:28 PM
fxman
Jul 22, 2011 07:10 PM
sweeperking
May 17, 2010 06:22 PM
johnthegoalie
Aug 10, 2009 12:24 PM
