balancer slipped?????
Old Jun 7, 2011 | 07:37 AM
vengence99's Avatar
I have 75 b200 / 318. this is my first dodge, I just installed a 4-barrel air-gap and a 625 carter afb in place of stock 2-barrel, when I went to time it I could'nt find the mark's. I went underneath, used white out to mark the balancer, hooked up the light and it was no where to be found. so I timed it by ear. it runs great. a little hard to start because the timing's off. could the balaner have slipped or did the timing jump?????
Old Jun 7, 2011 | 08:17 AM
I'm not sure, I think some of the vans had the timing TAB bolted on in a different spot. (on the passenger side). I would also "now swear" that some vans had the timing back through a slot/ hole in the bellhousing. But it's easy to check
Find, get, build, or buy a "piston stop" like this:
http://www.jerrybramlett.net/images/...stallation.jpg
Remove the no1 plug, make sure the piston is "down a ways", remove the battery ground for safety, and install the stop
Gently wrench the engine around until it "stops on the stop." You may have to adjust a first time setup. Matters not WHERE is stops, but you DO want the piston down somewhat, because----as the piston gets closer and closer to the top, it slows down past TDC, and this reduces accuracy of the test.
So with the piston against the stop, make a temporary mark under TDC on your timing tab.
Rotate the engine CCW until it stops again, and make a second mark. True TDC will be halfway between the two temporary marks, and if the factory mark is accurate, that is where it will be.
Old Jun 8, 2011 | 08:44 AM
vengence99's Avatar
thank you very much, i was right! the balancer did slip. I'm just going to buy an after market one and also put in gear drive. that should slove my problems. again thank you
Old Jun 8, 2011 | 01:56 PM
If your thinking about a cam gear drive, know that they can be noisy. My buddy has one in a big cam engine and with mufflers it sounds like a blower, very annoying.
Old Jun 8, 2011 | 04:56 PM
There's no reason to run a gear drive on a mild street engine, and they may not even be as reliable. Just buy a good quality (like Cloyes) "all steel" setup, no phenolic top sprocket.
Old Jul 1, 2011 | 11:44 PM
Buy a good quality dbl roller chain like used on the 340
alex_dodge1977
Aug 14, 2013 03:21 PM
LERaven
Jan 5, 2012 02:31 PM
tracktor312
Nov 19, 2010 05:50 PM
jar84203
Oct 2, 2009 05:17 PM
Commando
Dec 18, 2008 12:36 AM
