Battery not charging
Old Apr 1, 2014 | 02:59 PM
raycan2's Avatar
So I have the Car running good and all and about 3 miles from the house it dies..I jump start it and it runs for about 2 more miles and so on....I took the Alt off and took it in to NAPA and had it checked and its working great...What else can it be?When running I only get about 12.5 Volts on the Battery....
Old Apr 1, 2014 | 04:50 PM
pro-tech's Avatar
Voltage Regulator: It should be charging at 14.2 V no lower then 13.5 V...Does it have an amp gauge? alot of time the wires on the back of the gauge come loose...But it sounds more like the regulator...Keep us posted...Bill
Old Apr 1, 2014 | 06:28 PM
Probably the voltage reg You can up grade to a solid state regulator
Old Apr 1, 2014 | 07:37 PM
Does this still have the original pre--70 charging system?
If so your regulator should look something like this
https://s3.amazonaws.com/gearbox-yea...=450&width=600
and there should only be one "quick connect" wire on your alternator. A very quick check is to disconnect the quick connect at the alternator, and connect a clip lead to the terminal at the alternator. Connect the other end of the clip lead to the big stud at the alternator
If you are in subdued light, you should see a small spark when you connect / disconnect that wire. Start the car and bring up RPM. The ammeter should come up to charge. Monitor battery voltage with your multimeter. It should come up in voltage
Check voltage at the alternator stud as you bring up RPM. That voltage should come up as you bring up RPM, up above 12V. Don't let it climb up above 15 by much. IF it goes very high, much higher than 16, you have a problem between the output of the alternator and the battery that, is, the charging line
Voltage will depend on "how dead" the battery is. A battery that is pretty much charged will run somewhat above 12V, and a "normal" running/ charging battery with a proper operating regulator will run right at 14V.
If your jumper will not bring the voltage up above 12, the alternator is not charging. If the battery comes up some with the jumper is in place, likely a bad regulator. If the output stud goes WAY high, but the battery voltage stays low, then you have a bad connection in the circuit between the alternator output and the battery, that is, the ammeter circuit.
You have a service manual? Download one free here
http://www.forabodiesonly.com/mopar/...p?p=1970088617
or here
Old Apr 1, 2014 | 07:54 PM
moe7404's Avatar
i have seen a lot of guys wrap bare wires around the two AMP meter posts. then put a volt meter on it. a volt meter tells you way more about the battery than an AMP gauge.
Old Apr 2, 2014 | 05:23 PM
raycan2's Avatar
Looks like the Alternator ...I checked it with a meter and put the red (lead) to the big bolt and black (lead) to the ground and I am getting like .65 on it. I checked my wifes car just to make sure I was doing it right and I am getting 14+ on it..The deal is I took it off and had NAPA check it and they said it was fine...I guess I will put on another one and find out.
Old Apr 2, 2014 | 06:58 PM
Uh.................no.................
That does not sound right to me..........let's go over this again..........what did you do?
The car is just sitting there? Follow these destructions EXACTLY
Set your meter up to measure the battery. Measure the battery, make sure you get good connections, stab the probes into the battery post AND THE ENGINE BLOCK, with the engine OFF and measure about 12.6 or so with the battery charged.
Now go 'round and stab your probes into the engine block and the alternator stud
You should measure exactly the same voltage. If not you have a bad connection in the charging line between the alternator and the battery
Old Apr 2, 2014 | 07:39 PM
raycan2's Avatar
I will try that in the morning....
Old Apr 4, 2014 | 09:31 AM
raycan2's Avatar
O.K. So I did this and I do have the 12.6 on the battery and nothing on the alternator.So that does tell me its the wiring ..So from the alternator the wire goes to the Voltage regulator RIGHT?Then from the Voltage regulator to where?
Old Apr 4, 2014 | 09:42 AM
I’m gonna say alternator. if you did the same thing on another car and got 14+, you obviously did it right on yours.
The reason the car dies is it’s running 100% on your battery. Once the battery has no more to give, kaput——engine dies.
Now let’s just hope you haven’t damaged the battery because those are anything but cheap today.
Of course, the old school way to check is to take the positive post off when the car is running. If the engine dies, you have zero alternator.
Old Apr 4, 2014 | 09:50 AM
raycan2's Avatar
Well with the car running you should (I think) get 14 + on the alternator right? On the car with it running i am not getting anything.
Old Apr 4, 2014 | 10:17 AM
You haven't really done anything, all your test did was to establish the alternator might be hooked to the battery. Got back to my original post and follow instructions exactly
You must divide the problem into SECTIONS
1......is it a WIRING problem?
A..........is it field wiring?
B..........is it the charging line wiring?
2..........is it the alternator?
3..........is it the regulator?
So we do some testing................
The most very basic testing was my very first post, which is to eliminate the field wiring and the regulator. You remove the field wire from the regulator, and you hook a clip lead to the regulator field terminal. You hook that field terminal to a battery source, and you find out if it will charge. If it DOES charge, this eliminates two sections of the problem..........the alternator and the charge wiring, and leaves two sections..........the field wiring and the regulator.
The other approach is to take the alternator off the car and down to some parts store to have it tested. This is a POOR approach for several reasons. First, many of these testers are unreliable. Second, many of the test "operators" don't know what they are doing, and last, many of the test operators are interested in selling alternators, go figure!!!!
Please go back and read what I posted earler. I don't post this **** just to hear the keyboard rattle around
Old Apr 4, 2014 | 11:58 AM
raycan2's Avatar
That,s what iam trying to say 440 is that I did what you advice me and I am not getting the volts on the Alternator..I get it on the battery and when I check the alternator I do not get the voltsIi get on the battery....So its in my wiring I just have to find the connection.
Old Apr 4, 2014 | 02:19 PM
Somehow I misread, I owe you an apology.......
Read this MAD article, but the crux is their simplified diagram here:
Their simplified diagram is an excellent representation of the power distribution, follow along. From the battery, to the starter relay, the fuse link, and through the fuse link, through the bulkhead connector, through the ammeter, to the "welded splice, notice that you take off from the welded splice and branch off to several places, and feed off to the ignition switch, the headlights
BUT YOU ALSO branch off and COME BACK THROUGH the bulkhead on the black wire back to the alternator
This means there are ONLY THREE places that you are losing this connection
They are.........
most probable is the connector through the bulkhead
the welded splice itself, which is rare
the wire ring connector on the end of the wire at the alternator which could happen but rare
Also, if you don't have one, download the free shop manual link I posted above
And last, these wiring diagrams at MyMopar are not always complete, but are sometimes easier to follow:
These two diagrams
http://www.mymopar.com/downloads/1968/68CoronetA.JPG
http://www.mymopar.com/downloads/1968/68CoronetB.JPG
Old Apr 4, 2014 | 02:59 PM
raycan2's Avatar
They are.........
These two diagrams
LOL not a problem...Thanks for the info here.
Jonny
Nov 12, 2010 01:13 PM
69Bee
Jun 1, 2009 09:34 AM
Satellite_Guy
Sep 9, 2008 07:00 PM
Russ toy
Apr 25, 2008 06:08 PM
steve74swinger
Dec 26, 2007 06:34 AM
