? Best 340 Combos new project?
Old Feb 16, 2013 | 05:13 PM
duster3's Avatar
So here is the skinny, I am buying a complete 340 (carb to oil pan) from a very good friend and I want to build it for this coming up woodward dream cruise.
I want roughly between 400-500 horse at the crank
*Question- Do you guys have any proven combos for Cam, Heads, Intake, Carb, Headers, Converter...and whatever else I might need to get this kind of power!
I have 3.55 gears with a 8 3/4 so hopefully this is sufficient.
Needs to fit in my 73' Duster!!
Thanks again~ Sean
Old Feb 16, 2013 | 05:51 PM
500 HP is easy ! But what is your budget ??
Stick or auto ?
Old Feb 16, 2013 | 06:51 PM
duster3's Avatar
Stick or auto ?
Auto and around $2500 I think. I can put more into it after a couple months!
Even if I do not get it finished before August I still want to do it right and with the correct/ good parts that wont come apart after 5k miles lol
Old Feb 16, 2013 | 08:12 PM
What year is the motor? You might consider a stroker kit ? Shoot for 400 hp Spend the $2500 on the short block./ Re bore with KB pistons 9.5 compression, good balance job, 7 qt oil pan, windage tray STOCK oil pump. ARP main studs, & rod bolts. Use your current heads JUST do a valve job Save your money for some eddie heads later
Old Feb 17, 2013 | 05:06 AM
PK1's Avatar
PK1
Streetable 400 HP can be achieved as stated above. A stock short block with good compression and a set of higher flow cylinder heads and your at 400HP.
Budget wise use stock replacement parts in a cast or hyp piston, stock rods and stock crank. ( I'm assuming you have the rods and crank and need a new slug for a rebore?)
Get a set of EQ heads bare and set them up with a lightweight 2.02 valve. I think Ive spec'd machining on here before. This would change the oiling to thru PR design.
Add headers and Airgap
These heads will le you run a moderate cam. 224/230 or equivalent and hit your goal.
Nice part about this build is you can stroke it as suggested above and keep the heads, airgap, headers and put it back together.
Old Feb 17, 2013 | 03:49 PM
duster3's Avatar
Motor year is a 1971, anything odd I should know about this year?? Also why did you capitalize windage tray "STOCK" oil pump? I guess I do not know much about oil pumps for this. lol
Old Feb 17, 2013 | 04:58 PM
duster3's Avatar
@TVLynn
What cam should I use? Brand, lift, duration
Old Feb 17, 2013 | 11:18 PM
71 may have a cast crank ?? The HV oil pump hits on the oil pan most of the time & requires some grinding. Also a HV pump can suck the pan dry at extended high RPM. The stock pump is actually quite good...
Old Feb 19, 2013 | 09:52 AM
duster3's Avatar
@TVLynn
Thanks again for the info. I had no idea about the HV pumps being able to dry out the oil pan, I have never heard that before.
Good advice!
Old Feb 19, 2013 | 11:23 AM
I have done it on a stock 360 pan. Chevies need a HV pump Mopars don't. So unless you are olanning 8-9K RPM's it is not necessary. YOU need a minimunm 7 qt oil pan if you use a HV pump
1 Bad Mirada
Sep 10, 2016 08:26 AM
spoolin6er
Jun 29, 2013 10:00 AM
Howard Poulter
Aug 1, 2010 02:13 AM
Biggins
Dec 16, 2009 05:36 AM
lloyd1701
Dec 5, 2009 12:36 PM
