casting numbers???
Old 02-01-2009 | 06:24 AM
rr69half6bbl's Avatar
the casting date for the block will be on the pass. side of the block right behind the motor mount bosss. be like 3 09 68. remembe rthat the model year started in early sept. through, end of aug. and the fender tag will have the cars build date on it . the casting date on the block will be before or no later then 5 days prior to the cars build date. If the block is like 7-15-68. then it was an early prod. 69 block. the vin numbers of the car should aslo be stamped into a flat space on the pass sid eof the block right above the pan rail. then the vin will also be stamped on a flat pad on the pas side of the trans at the very front above the pan also.
Old 02-01-2009 | 06:51 AM
Polaradude's Avatar
Mopar casting dates can be on either side of the block in the format mentioned above, also there will be a clock like looking thing with one or two pointers pointing to a time of day the block was cast, also there can be a D or an N denoting day shift/ night shift. Actual part #'s will be on the rail of the block just above the oil pan and/or on a boss close to the dizzy.
hizen
01-07-2012 07:59 PM
71mopar
11-24-2011 07:20 PM
Leem
08-31-2010 07:47 AM
henryj
12-19-2009 09:21 AM
Stauff73
10-19-2009 02:23 PM
Quick Reply: casting numbers???
