check engine codes 2-6 2-7
hi i have a 1990 dodge daytona and my check engine light came on today spitting out codes 2-6 and 2-7 which mean that one of the 6 injectors peak pwer is not being reached and one of the 6 injectors is not making a complete circuit does anybody know what this could be from or and ideas of how to go about fixing it? thanks for all the help all tips are greatly appreciated
What motor? From the factory manual I have, it says to use the drbII scan tool and go to the Actuate screen and that would allow you to test the injectors individually. At least thats what I understood from the manual.
you may have pinched wires or corosion on your injector plugs, or the plastic housing around the injector plugs rotedd and broke from time and engine heat, and the connection could be grounding out against the fuel rail. just a suggestion. but if you go to autozone, they test the car for free, you can at least find out exactly which injectors are bad, then try changing them your self.
chlfan
12-09-2006 07:57 AM
