check engine codes 2-6 2-7
Old Oct 18, 2009 | 03:14 PM
Daytona45's Avatar
Junior Member
hi i have a 1990 dodge daytona and my check engine light came on today spitting out codes 2-6 and 2-7 which mean that one of the 6 injectors peak pwer is not being reached and one of the 6 injectors is not making a complete circuit does anybody know what this could be from or and ideas of how to go about fixing it? thanks for all the help all tips are greatly appreciated
Old Oct 18, 2009 | 04:31 PM
scotts74birds's Avatar
What motor? From the factory manual I have, it says to use the drbII scan tool and go to the Actuate screen and that would allow you to test the injectors individually. At least thats what I understood from the manual.
Old Oct 19, 2009 | 09:23 AM
Daytona45's Avatar
Junior Member
i dont have any diagnostic tools and i have the 3.0l v6 its a twelve valve sohc. thanks for the help
Old Oct 22, 2009 | 01:52 PM
rr69half6bbl's Avatar
you may have pinched wires or corosion on your injector plugs, or the plastic housing around the injector plugs rotedd and broke from time and engine heat, and the connection could be grounding out against the fuel rail. just a suggestion. but if you go to autozone, they test the car for free, you can at least find out exactly which injectors are bad, then try changing them your self.
justabrit
Jun 19, 2011 07:00 AM
65AzBel
Dec 2, 2008 03:01 PM
chlfan
May 29, 2007 12:32 PM
499coronet
Mar 17, 2007 09:26 PM
chlfan
Dec 9, 2006 06:57 AM
