cold batt dead
Old Jan 6, 2014 | 06:38 PM
moe7404's Avatar
cold batt dead
been sick 4 days. cold weather had my son start my twk 3 days. not Sunday, last nite temp -5. twk would not start 2 hrs ago. now i pray the batt doesnt frzze.
Old Jan 6, 2014 | 06:52 PM
Mr.4spd's Avatar
Jeez Moe, where do you live? Here in NH we've seen temps around -5 F lately and I've had no problems (though my Journey turns over kinda slow). Maybe time for a new battery?
Old Jan 6, 2014 | 07:19 PM
moe7404's Avatar
i have lived in Wichita ks from 1948. lowest temp i have seen was -10 f. weather man said the EVER lowest temp in ks is -33 f. i have never lived where i did not have garage next to my twk till now.
Old Jan 6, 2014 | 08:05 PM
ZombiePopper's Avatar
Yeah the weather sucks here in KS, probably oughta throw a trickle charger on your Batt Moe, my tractors (diesel and gas) are both slow sloooow cranking, I had to throw a charger on my JD diesel the other day, I hate winter, not to jinx us,
But at least we haven't had any of that ice rain crap...yet
Old Jan 7, 2014 | 09:23 AM
moe7404's Avatar
tue 11:00 am just ate breakfast with mom. got my batt chargers and got one on my batt. it started at 12 amp dropped to 8 amp in 10 sec, so the batt should still be good. will check it latter, the plan is to cut amp down to 2 amp for over nite. new starter and batt 4.23.13 UPDATE: tue 3:30 pm started engine. had to keep RPM at 1200, so would not die. after engine temp at full it would idle fine. air temp 39 F. will leave charger on over nite. still praying.
Old Jan 8, 2014 | 11:35 AM
moe7404's Avatar
more update: Wed 8 9:00 am. starts fine, runs fine. with the higher temps i think iam back to normal. but being sick, and very cold outside AND twk trouble all at the same is NOT fun. i would NOT wish it on ant one.
Old Jan 8, 2014 | 05:58 PM
You need a block warmer Moe....
http://www.jegs.com/p/JEGS-Performan...52718/10002/-1
Old Jan 8, 2014 | 06:04 PM
..........and get what's called a "battery tender"..............
Old Jan 8, 2014 | 06:05 PM
That will help keep heat in the battery....And not over charge it...
Old Jan 8, 2014 | 06:57 PM
moe7404's Avatar
you cats are so right as all ways. all so i really need a lower weight oil. 15w-40 doesnt work good at -5 f. and head lite not coming on is fine now. the autolite AR3933 plugs seam to be doing fine put in last nov. my fan belt is making a noise. will take to shop Friday.
Old Jan 9, 2014 | 06:29 PM
Yep... A 5W20 will start allot easier....
Old Jan 9, 2014 | 07:51 PM
moe7404's Avatar
well iam going to have to stop calling those oils water. for give me dad.
91shadowTurbo
Aug 9, 2010 05:30 AM
will d
May 9, 2010 09:41 PM
Cure
Apr 21, 2010 10:32 PM
68 Sat
Feb 7, 2010 05:24 AM
deadkelly
Oct 30, 2009 07:57 PM
