couple off the wall? 's
Old Feb 5, 2014 | 06:08 PM
ratrodney's Avatar
Question couple off the wall? 's
Hello.
I'm looking at a few big blocks to choose from for my ratrod project.
a 76 440 n 727 Congo out of an Rv is one of em.
I know the Hp n tourque rating is kinda low on em and ive never had a bb in a project before as its always been a sbc. But....will a lets say 250 Hp big block Chrysler be good noticible feel as far as performance? Or will a sbc with 400 horses blow it out of the water?
I'm asking because ive always heard that a big blocks power n tourque is very noticible as compared to a small blocks.
I guess I'm just wondering is Hp just Hp or does it feel n come in different on bb n sblocks?
tnx....RR
Old Feb 5, 2014 | 10:33 PM
Torque is a function mostly, of the overall engine build AND THE STROKE
Since you can buy some "big ***" stroker kits for small blocks, much of this gap has largely been closed.
The big difference in a so called "RV" engine will be the top end and cam, along with compression ratio. If you just want a torqu'ey street engine, and as long as the RV engine is not a "heavy truck" engine IE the ones with the "high mount" water pump which connects to the fronts of the heads, you likely can put a little more cam in there with a nice aftermarket 180 degree intake and make a pretty snappy budget engine. Good manifolds or headers and duals. After that comes better heads, and higher compression
A factory 440 is 3.75" stroke, a 318 is 3.3" and a factory 360 is 3.58" but a 408 stroker kit brings a 360 out to a whopping 4" stroke
Old Feb 6, 2014 | 08:12 AM
ratrodney's Avatar
Sweet.
Its goin in a light weight rat rod. Is the truck motor bad because of the way the water pump is set up or due an issue with the engine itself? Im asking because i havent set up a cooling system yet and can make whatever style work. tnx...rr
Old Feb 6, 2014 | 09:52 AM
I'm sure the heavy truck engines are heavier, but the thing is, the heads and water pump are DIFFERENT. You would not want, example, to put a bunch of money into the heads and then have to round up another because of a crack or other problem
Also, the heat crossover in these heads is NOT exhaust as on light truck / pass car engines, but rather water. I would guess that aftermarket manifolds would be a problem. If you got one of these engines cheap enough, you could use essentially the shortblock and put different heads on. It would be fairly low compression.
aceofspades
Jan 9, 2014 03:06 PM
Kris Huen
Jun 11, 2012 09:06 AM
deadkelly
Apr 15, 2010 02:52 PM
Cracocuda
Feb 10, 2010 09:06 AM
Nebi
Jul 29, 2008 05:44 PM
