Cracked 360 Heads
Old 04-27-2010 | 04:46 PM
79woodnick's Avatar
Cracked 360 Heads
I'm having my '79 360 engine rebuilt and ran into a problem with the heads. 1st the heads on my engine showed cracks around one or two valves then we found some cracks in the replacements. Is this a problem with this era engine?
Old 04-27-2010 | 05:19 PM
could be from them overheating or not getting enough oil. I do know that the LA heads usually need to be rebuilt every 75,000 miles.
Old 04-27-2010 | 07:32 PM
1966sportfury's Avatar
A.K.A Bob Dodge
i never heard of that nor had a problem after 75,000. X my fingers!
whys that? valve guides?
ive seen a few cracked heads. crack between the exsaust and intake dont kn ow for sure what caused it. my guess is overheating
Old 04-27-2010 | 09:00 PM
74 Charger man's Avatar
Junior Member
1966Sportfury is 110 % right ! they crack like a ford right between the valves. that is over heating and cooling off fast . The way I think that happens is the coolant doesn't travel far enough like to the heater core or is pluged or disconnected or cousing a bubble in the system . Or you block deck isn't true . Find a stright edge and check you block deck . maybe your intake has a slight leak .
Old 04-27-2010 | 09:55 PM
Junior Member
Um your not buying old race cylinder's are you ? Where the race engine's use a steel shim gasket kit . becuase they dont seal and are not flexible . maybe your best bet is to buy new heads with 2.02 and 1.60 valves . like INDY or WORLD OR ELDERBROCK . with a macthing intake and card set up .
74Runneer
02-27-2013 07:24 PM
CantRamItDodgeIt91
11-22-2010 07:12 PM
Live Wire
10-07-2010 10:00 PM
unclemike
10-11-2007 07:31 PM
ProEmaster
03-01-2007 01:19 PM
