exhaust manifold repair
Old May 18, 2014 | 05:09 PM
nashvegas99's Avatar
ok, so I found a pretty good crack on my exhaust manifold on the 225. I know that I've got to get a new one or have the old one welded, but would that "Quicksteel" work to fill the crack until I can get it welded or replaced?
Old May 18, 2014 | 06:17 PM
I'd say go ahead, a replacement should be easy to find or maybe time for a header.
Old May 18, 2014 | 08:21 PM
moe7404's Avatar
the slant 6 ext manifold must installed in a very specific way. here is THE BEST info.
http://www.slantsix.org/articles/man...s-mounting.htm
Old May 18, 2014 | 08:44 PM
FOLLOW the directions Failure to use the correct hardware will result in another cracked manifold
Old May 19, 2014 | 06:05 AM
well,I think I'm hosed on this one. it appears that the crack is all the way around and once I remove the manifold the horn will be separated from the rest of the body. guess im looking for a used one somewhere. I was told that the late 70's and early 80's exhaust manifolds will fit. any idea if that is true?
dnlwstwd
Oct 12, 2011 08:08 AM
Jeeman04
Jan 2, 2010 10:36 AM
THE GOOSE
Sep 6, 2009 06:06 PM
M1 Manifold
May 21, 2009 02:23 PM
LanceFury
May 27, 2008 12:33 PM
