Firewall to Floor Pan Seam ? Removal
After I get as many spot welds out of the seam what are some ways to get the seam apart ? Replacing floor with one piece floor pan in 65 Satellite and seam in and around the firewall is a tight area to work at the best of times ?
Any tips ?
thx
Any tips ?
thx
once you get past that part, can you use an air chisel with a weld breaking bit? I've done it on other cars, and once you have them seperated, you need to use a hammer and dolly to get your metal back flat to match up. Patience, patience, and more patience as you're doing it will help keep the distortion to a minimum.
Mango
Feb 12, 2011 10:39 PM
