front end change
Old Jul 8, 2011 | 12:42 PM
sgp7679's Avatar
Question front end change
Im having an issue with my front end, i just had my front end alignment done not to long ago, and for some reason sometimes when i drive, i can feel the alignment go wrong then I will hear the front wheels screeching and when you look at the car from the front it has a really positive camber. Sometimes if i hit a bump or something it will (fix) itself and be driving straight with normal camber. Ive had all ball joints replaced, tie rod ends. upper control arm bushings replaced. Im thinking its a bushing is going out that i dont know about? 65 coronet
Old Jul 8, 2011 | 12:43 PM
sgp7679's Avatar
also, wasnt a bad alignment, car has done this before in the past, just a more frequent problem now.
Old Jul 8, 2011 | 06:10 PM
Sounds like a lower control arm bushing to me. If the rubber looks all cracked or not visible then probably done. You can take a bar against the arm and pry it outward and see any play. If you have some one jack it up under the crossmember while you watch at the torsion bar this can show the play as the weight comes off.
Old Jul 8, 2011 | 06:48 PM
scotts74birds's Avatar
last time you posted on your front-end, I could swear we mentioned your lower control arm bushings. Did you do 'half-a-rebuild and now wonder why something is wrong?
Old Jul 8, 2011 | 06:50 PM
Crazy4Carz.Com's Avatar
X2
masonw
Jun 20, 2013 11:45 PM
bruger
Jul 16, 2010 10:14 AM
1969GTX
Apr 5, 2008 06:20 PM
Liu Kang
Mar 25, 2008 06:13 PM
Crsher
Mar 19, 2008 02:50 PM
