fuel sending unit
Old Oct 4, 2008 | 12:51 PM
nailbender's Avatar
Junior Member
fuel sending unit
Do I have to remove the gas tank to remove the fuel sending unit on a 68 barracuda?
Old Oct 4, 2008 | 03:45 PM
ef8340's Avatar
Senior Member
yup make sure to use a brass pin or non metal rod to remove lock ring dont want any sparks
Old Oct 9, 2008 | 06:47 AM
rr69half6bbl's Avatar
also , when you remove the old and install the new , make sure that you carefully r&r them as you have to twist the unit as you go. straight up then straight down towards back of tank, so that the unit almost touches the tank then straight up. on removal, then on install just reverse, or you can bend the float or neck, and mess up the reading your gauge will get.
twalace
Aug 8, 2010 10:23 AM
Aspen
Aug 31, 2009 10:28 PM
Evnas
Apr 12, 2009 06:13 PM
mopar nate
Jan 25, 2009 09:12 AM
64fury
Jun 16, 2008 12:40 PM
