Help please. Alternator not charging.
Old 04-06-2014, 04:31 AM
BrandonLee4467's Avatar
Unhappy Help please. Alternator not charging.
I converted my 360 magnum from efi to carb and now I need to know if there is a way that I can bypass my PCM so that my alternator will charge my battery and all th at good stuff.
Old 04-06-2014, 04:56 AM
Welcome. A quick search found lots of info.
http://dodgeforum.com/forum/1st-gen-...onversion.html
http://alternatorparts.com/external-...nator-kit.html
BrandonLee4467 (04-06-2014)
Old 04-06-2014, 06:30 AM
Well at least PART of that diagram is wrong. "12 V from battery" should read SWITCHED 12V from KEY That is you do not want hot at all times, you want switched 12v in "run"
Here is the basic diagram from the 70 / later regulator:
http://www.mymopar.com/downloads/Dua...tor_Wiring.jpg
Basically, the terminal indicated from the VR goes to either field terminal of the alternator.
The terminal indicated of the VR goes to switched "ignition run" from the key.
It is IMPORTANT that the regulator be GROUNDED to "same as" battery negative
mikeynags
06-16-2009 08:19 PM
mikeynags
06-16-2009 06:31 PM
69Bee
06-01-2009 09:34 AM
Russ toy
04-25-2008 06:08 PM
steve74swinger
12-26-2007 06:34 AM
Quick Reply: Help please. Alternator not charging.
