Holley Carb Draining into Intake
Old Mar 25, 2021 | 03:59 PM
lahatte's Avatar
When I started my engine cold, it ran for a moment, then started to die, as if flooded. Going over to the front of the car I can hear the gasoline draining into the intake.
Anyone know why that might happen? I don't have reason to suspect a bad powervalve yet, but I'm still investigating.
Thanks.
Old Mar 25, 2021 | 04:10 PM
Holly neddle and seats have a tendency to stick when dirty, try giving them a clean and adjust the floats.
Old Mar 25, 2021 | 07:18 PM
lahatte's Avatar
I have replaced the front needle and seat already. I suppose maybe the rear one could have an issue. I haven't removed it yet.
I had leaking issues at the front and just replaced the accelerator pump diaphragm, which seems to have stopped that leak, but now I get fuel under the rear accelerator pump.
This carb was purchased 10 years ago from a rebuilder, and doesn't have a lot of running time on it. It had been great until I tried to start the car last fall and got the flooding issues.
Old Mar 25, 2021 | 07:49 PM
I've never had any luck storing carbs, i generally put a kit in them before I use them again after sitting.
Old Mar 26, 2021 | 07:26 AM
I agree, all the rubber drys out and cracks, and will add to also check the floats to make sure they are also still good...
Old Mar 26, 2021 | 08:22 AM
Archer's Avatar
la -
Assuming the carb is intact (and I agree a rebuild might be in order), you did check the float levels, right (assuming a Holley)?
Mopar4Llfe
Jul 8, 2014 06:05 PM
razalas_89
Jan 12, 2013 04:57 PM
69POLARA383
Aug 28, 2011 06:08 PM
HellRazor1200
May 19, 2011 08:56 PM
craveman
Sep 30, 2009 03:05 AM
