how to adjust kickdown linkage to tranny
Old Jun 1, 2009 | 08:46 PM
nesparky's Avatar
How do you adjust the linkage from the carb to the tranny. This is in a 78 cordoba with a 400, thermal quad, and a 727 trans?
Old Jun 2, 2009 | 03:47 AM
Crazy4Carz.Com's Avatar
With the engine off, push the throttle wide open. This should push the kickdown all the way back. Adjudst from there. If it kicks down too soon back it off a little, easy as that.
Old Jun 2, 2009 | 06:48 AM
72RDRNR's Avatar
It is best to have someone step on the pedal from inside as opposed to WOT from the carb linkage. There may be a difference in the two.
Old Jun 2, 2009 | 06:50 AM
72RDRNR's Avatar
Little fuzzy on shift pionts --- 15-20mph and 25-30mph (I think).
Old Jun 2, 2009 | 08:26 AM
Good thought. There should be no difference but sometimes there is. While doing this be sure you are getting WOT (wide open throttle) with the pedal. Have someone press it to the floor and then manually push the throttle open to be sure it is in fact opening all the way. I have seen many that think the car is supercharged after getting to use all four barrels. If the pedal is not opening the carbs all the way you may be running your hot rod at half throttle.
josehf34
Dec 9, 2013 05:57 PM
KJoeZ61
Sep 27, 2009 05:07 PM
Iskone
Jul 4, 2009 08:25 AM
DartConvertible
Mar 28, 2008 06:24 PM
button
Jan 26, 2008 05:30 PM
