How much can i safely machine off a magnum head valve base pocket
Hey all
I want to run a solid roller cam which has a lot of lift .609 in my 360 magnum. From memory they have a installed height of 1.65 so to run the springs to get the pressures I need I need a slightly taller installed height.
I have heard the magnum heads are prone to cracking so what's the safe amount I can take off the spring pocket if any at all?
cheers
Or does anyone know if there are retainers available to improve install height.
cheers
Thanks guys
Longer valves are an option if I cant machine the pockets.
I have tried to find + 0.050 keepers and retainers but cant find any at all.
The magnum seems to have an uncommon size valve. 8mm
If anyone know where I can get them please let me know.
Thanks
Thanks
Dave E
13
03-10-2014 01:06 PM
Sombeitch
09-24-2011 10:06 PM
