How much can i safely machine off a magnum head valve base pocket
Old Jul 2, 2014 | 09:35 PM
maca's Avatar
Hey all
I want to run a solid roller cam which has a lot of lift .609 in my 360 magnum. From memory they have a installed height of 1.65 so to run the springs to get the pressures I need I need a slightly taller installed height.
I have heard the magnum heads are prone to cracking so what's the safe amount I can take off the spring pocket if any at all?
cheers
Or does anyone know if there are retainers available to improve install height.
Old Jul 3, 2014 | 07:08 AM
maybe some longer valves
Old Jul 3, 2014 | 09:30 AM
Drag Pak's Avatar
I believe most aftermarket suppliers have + 0.050 keepers and retainers, which will help a little.
Old Jul 3, 2014 | 02:58 PM
maca's Avatar
Thanks guys
Longer valves are an option if I cant machine the pockets.
I have tried to find + 0.050 keepers and retainers but cant find any at all.
The magnum seems to have an uncommon size valve. 8mm
If anyone know where I can get them please let me know.
Thanks
Old Jul 3, 2014 | 04:05 PM
I have only heard not much, maybe .050" max.
Around here there are lots of cracked ones to cut in half. Maybe a call to a machine shop might find a failed one.
Old Jul 3, 2014 | 05:52 PM
maca's Avatar
Good idea but they are rare in Australia as no vehicle was ever released with one here.
I will keep hunting around
Cheers
Dave E
13
Mar 10, 2014 12:06 PM
Sombeitch
Sep 24, 2011 09:06 PM
Braffit
Dec 29, 2010 02:28 PM
Buffalojoe426
May 14, 2010 03:42 AM
cudanut476
Jul 7, 2009 04:10 PM
