How would YOU build a stroker SB street motor?
Guest
Posts: n/a
For an econo build - using premium pump-gas...I was thinking a 4" cast-crank in a 360 block. Pistons and rods are up-in-the-air but heads would be the Eddies with a target compression ratio of about 11 to 1. How about YOU ?
Hey DOC i have heard good things about this place , maybe this will help www.Campbellenterprises.com
