I NEED HELP WITH CASTING NUMBER
Old Sep 18, 2011 | 02:57 PM
northcoasttip's Avatar
4006630-360-7 is the casting number on my motor! i only came across 4006630 as a 440cid! what do i have?
Old Sep 18, 2011 | 03:22 PM
MercuryDon's Avatar
There will be a machined pad facing up on the block right behind were the water pump goes and it will be stamped 440 if you hava 440. The distributor will also be in the front. If there is no machined surface and the distributor is in the back you have a small block most likely a 360 as that is in the casting number you gave above. Small bocks are stamped on the block just below the drivers cylinder head.
Old Sep 18, 2011 | 03:30 PM
Thanks
Thank you! these casting numbers can become confusing
Old Sep 19, 2011 | 11:43 AM
by any chance do know what year 360 it is?
Old Sep 19, 2011 | 02:53 PM
MercuryDon's Avatar
The date code should be stamped on the block below the drivers cyl head. there will be a letter for instance E=1969 F=1970
Old Sep 20, 2011 | 08:12 AM
cool thank you!
rdoylejr
Aug 17, 2014 10:01 AM
hornback65
Dec 9, 2012 04:43 PM
moparwannabe
Nov 9, 2010 06:28 PM
ozyditcher
Jul 11, 2009 10:36 AM
darkcrow
Feb 1, 2009 06:51 AM
