It's in.
1 Attachment(s)
Maybe one day I can get the pics right. Click on pic.
Looks nice! Is that a blower pullly on the front of it?
electric water pump drive
Duster
500ci. All forged , Scat crank ,Eagle H beam rods , Ross flat top w/ reliefs , Comp cams roller cam, Promaxx heads. Harland sharp roller rockers, main studs w/ alum. caps, 1050 Dominator. W/ Mopar intake. Hasn't been out of the garage yet! Hello Bob.
Originally Posted by Skynyrd
(Post 136906)
Duster
It was just a 30 over then. He ran 6:50. 1/8.
That's a nice ride, 9.70s in the quarter.:)
(Post 136906)
HELLO AL.... GOOD TO HAVE YOU BACK !!!!!!!!! |
Duster
Good to get back some of my stuff over to this phone. Couldn't get the g mail to work either. Lol not so savy. Fired engine up again today. Been running and trying to set timing. I think it needs about 36. Builder says it should idle around 10 or so. The cam is degreed , ati balancer and is set to tdc at true tdc #1. Builder says rev to about 3500 and set to 36 and see. Msd pro billet distributor and I'm not sure what the diz has in it. It's not locked down. Anyway I'm missing something. When we idle it seems good but when we start reving towards 3500 it shakes and runs like crap. I set to 36 but it's not right. Any thoughts or outrite help.
Duster
Good to be back. I have learnt so much talking to you guys. Thanks
ok.... Start the car... Warm it up... Set the timing to 14* to start off with....
Run the motor up to 3500-4000 rpm and read what the timing is.... If its going past 36* ? Then Distributor will need to have the curve adjusted.... :) |
Going by the discription it sounds like you're up against the two step or the rev limiter.
(Post 137020)
Advance should be all in by 2500-3000 so try setting timing in that range @ 36 then look at idle timing. How big is the cam?
Make sure two step is off and rev limiter is set high enough, say 6000 to start.:) |
Cam
It's something like 280/730 custom comp cams.
Cam
Rev limiter is like 7000 The two step doesn't activate until trans bk. Is held. But I'll check that out.
Timing
We used this distributor and ignition set up last couple yrs. if that helps. But I will try this next. And see what we get. It doesn't sound like the two step , runs like it's out of balance , rough. It's all balanced. I'm going to check valve adjustment also. Hasn't been checked since being built but it hasn't ran much either. Let you know what I find. Thanks , it's supposed to be in the 60 s Christmas. 40s and 50s next few. So hopefully I can get this lined out. Then it's off to be lined up.
? IDK do you?
Hummmm... Has it Always done this sence you put it back in and got it running?
What is "IDK do you"? Sounds like CIA talk jargin. Or someones going fishing !! !!!!!! |
I believe the MP benchmark timing is recommended to be set at 2000 rpm.
Here is a link to their various total mechanical timing benchmarks. I've used it with great success in the past. http://wawii.com/m37/manuals/MoPar%2...lecignconv.pdf You can probably just scroll down to page 5 or 6. and there is also a few troubleshooting examples. |
(Post 137042)
(Post 137014)
Originally Posted by Drag Pak
(Post 137048)
I Don't Know...... Bob do you?
There that's out of the the way......... I asked what size your cam was because I run 38 total with only 5 to 10 advance in the distributor, my FT cams are in the 280 + @ .050 lift range.And yes thats a lot of initial timing. You want all your advance in, depending on the cam and fuel,by 2500-2700. |
Hummmmm.... Al... Also... Sorry, I'm getting forgetful... But are you running the full msd system?
If so... The timing light your using might be giving you grief ????? Some of the timing lights "Inductive Picks" do not like the multi-spark and throw the light way out of wack... Just food for thought... https://www.msdperformance.com/suppo...ng_techniques/ Oh.... Thanks Tom.....I get it know.....Hahahahahahahahahaha |
Tune
Yes msd 6
(Post 137056)
If so... The timing light your using might be giving you grief ????? Some of the timing lights "Inductive Picks" do not like the multi-spark and throw the light way out of wack... Just food for thought... Inductive picks hu? Never heard of that lol. That's not saying a whole lot. How would you know ? I had heard that before. https://www.msdperformance.com/suppo...ng_techniques/ Oh.... Thanks Tom.....I get it know.....Hahahahahahahahahaha |
Ooops... On the MSD Tool bar... Go to "Timing Fluctuations".... Sorry my bad... I should have checked the link.... :)
Timing
Ok we obtained a Blue Point digital timing light EETL5568. Off snap on truck. Hopefully it will get the job done. Probably going to try it tomorrow . Heat wave coming 67 Monday. So warm up engine set idle to 14 Rev. to 3500 if it goes past 36 we will have to work on dizzy. Ok Bob I'll let you know. Merry Christmas brother. Al
