k-frame for Hemi
Old Apr 30, 2025 | 05:23 PM
Ramo#7's Avatar
k-frame for Hemi
I have a 1967 Plymouth Belvedere with the standard K-frame. I am going to install a 426 Hemi and I have heard that the k-frame is different ? can someone tell me what they are ? can I weld in different motor mounts and use the same k-frame I have ?
Old May 1, 2025 | 04:50 AM
Finoke's Avatar
The easiest way to do this is to keep your current K frame and use conversion motor mounts if available. Schumacher Creative may have what you need if your car currently has a V8. Remember, you will probably need to change your torsion bars if you currently have a small block in the car. But you can keep your current k frame.
Old May 1, 2025 | 05:25 AM
Kuvasz101's Avatar
I agree with Finoke. You can buy mounts for your K frame that are meant for a hemi conversion. The Torsion bars for a hemi are firmer and easily changed out. After you shoehorn that elephant in, you'll have a cool ride!!
Old May 24, 2025 | 05:13 PM
seriong_hoo's Avatar
No, a standard 1967 Belvedere K-frame is not the same as a HEMI version.
Old May 25, 2025 | 05:01 PM
Ramo#7's Avatar
Thank you. I have the car completely stripped so I will look at the torsion bars that were in it and what I can go to upon assembly.
Old May 25, 2025 | 05:04 PM
Ramo#7's Avatar
Thank you. I have looked in to the different motor mounts the first couple guys suggested and will likely go that route. If not i will fabricate something.
Old May 26, 2025 | 06:01 AM
There’s something to fabricating your own mounts, I’ve never bought any from any source but have seen the problems written about them on the forums. Usually the transmission mount is a given so you have a place to start from there it’s just getting the engine transmission square in the chassis with about 4 degrees up in front. You can bolt everything together before finalizing your mounts and welding. I would recommend sandblasting the K member and repairing it as needed, all cracks and broken welds. One thing I believe the Hemi K member has a small skid plate on the cross member so don’t forget that.
good luck , have fun
btrottie
Jun 16, 2021 08:19 AM
acln99
Feb 13, 2011 02:17 PM
44070dart
Oct 18, 2010 08:29 AM
TerryThib
Sep 4, 2009 09:06 AM
