LED interior lighting
Just thought I would share this with everyone.
www.superbrightleds.com
First awesome LED light website I have ever found.
They had correct listings for every light in my 1968 Chrysler newport including map light, dome light, side markers etc..... The 360 degree led's are a little more expensive but look great in the old dashes. IMO.
Hope this helps someone out!
Gary
Gary
Just about the entire car is done in LED bulbs in my case. Brighter with less power draw and much better at night. I had to install an electronic no-load flasher and if you do this, and it appears not to work, reverse the wires at the socket because the flashers are polar sensitive. I used a "Grote" flasher and most of the others are identicle - 2 prong with a ground wire and a direct fit. My bulbs came from Superbright LED's and I have no complaints what so ever. Now when I turn on my signals I don't get the interior lights strobing dimmly in time with the signals.
