which is more desirable for a 70 cuda?
Old Feb 17, 2012 | 02:21 PM
barry's Avatar
I would love opinions on the desirability of an original 70 cuda V code convertible with a date coded 440 engine versus a 70 cuda convertible with a matching numbers 383 engine. assume the condition of both cars is the same. Also, which one do people consider a better long term investment.
thanks
Old Feb 17, 2012 | 03:26 PM
mikerp76's Avatar
i would say the numbers matching car would be worth alot more.
Old Feb 17, 2012 | 04:28 PM
You're kiddin me, here, right? A V code, even if it's not a matching block, if done otherwise correctly, should be worth WAY more money
The cat's meow with a car like that would be if you could find a "warranty" block to put in it.
Old Feb 18, 2012 | 03:56 PM
barry's Avatar
the car already has a date coded 440 six pack. what is a warranty block?
Old Feb 18, 2012 | 05:04 PM
A date coded block would probably be just as well. A warranty block is exactly what the name implies -- "back when" the car was under warranty the owner ruined the block, and the factory replaced the block/ short block/ long block on warranty. So the numbers no longer match.
Back before the "big financial crash" I've seen Cuda sixpack and hemi BODIES WITHOUT an engine go for nearly as much as a running 383 car.
Did you say this is a ragtop? I'll bet there weren't all that many made. Make sure they are "legit" and not a "rebody."
Old Feb 19, 2012 | 03:54 AM
barry's Avatar
it is a real convertible. according to production stats only 29 v code convertibles were produced of which 12 were auto. it is legit and documented
Old Feb 19, 2012 | 08:16 AM
In that case I don't see any possible way that a 383 car would ever be worth more money.
Old Feb 19, 2012 | 01:20 PM
barry's Avatar
thanks
Old Feb 20, 2012 | 07:23 PM
moparted's Avatar
the v code is worth 1/2 what it would be if the numbers matched
josehf34
33
Jan 31, 2014 10:12 AM
robertherr
Mar 4, 2012 05:49 AM
robertherr
Feb 18, 2012 03:17 AM
Valcam
Jun 4, 2009 11:47 PM
Doc
Jul 6, 2008 11:10 PM
