? moving shifter
? how to remove shifter
How do I remove this shifter so I can pull engine and transmission? Don't want to jump all in doing without advice and have the whole thing tore apart. I also think it is missing the PIVOT BOLT BRIDGE PLATE. And I have removed the bolt that runs across from each side looking like it would go through the bottom of the handle but handle still doesn't come out.
That little tab sticking out of the left side of the mount is the spring clip, the feeler gauge should work well, I have always just used the push/pull method without any issues (some are more stubborn than others)
I took the whole thing out...made it a lot easier to pull motor and tranny
I labeled the linkages Left, Right and Center before removing them...I took lots of pictures underneath so that I could come back to them and not be a big dummy when putting it back together...I can take another pic...tonight that will show you what bolt to take out
You're making this way way waaayyyyyy to much of a head banger. You've already made "the step" but you almost can NOT get that put together wrong.
Don't you have a shop manual? See here: Download one fer free:
http://www.forabodiesonly.com/mopar/...al%2C+download
Only difference between the picture below and yours is that yours is an overdrive. 3/4 gear (front) lever is upside down in the OD application
Thanks for the pictures. I got the shift handle out in next day or so will remove the shift handle assembly will most definitely label the rods. Just waiting for someone to be around while I crawl underneath the car.
The linkage may have minor differences over the years but it works exactly the same.
