? moving shifter
Old Mar 29, 2011 | 03:27 PM
1971superbee's Avatar
? how to remove shifter
How do I remove this shifter so I can pull engine and transmission? Don't want to jump all in doing without advice and have the whole thing tore apart. I also think it is missing the PIVOT BOLT BRIDGE PLATE. And I have removed the bolt that runs across from each side looking like it would go through the bottom of the handle but handle still doesn't come out.
Old Mar 29, 2011 | 06:05 PM
mr340's Avatar
In one word or less... PULL!
Old Mar 29, 2011 | 06:31 PM
That method didn't quite work. Did come across a subject about a shifter in a ford where you have to slide a feeler gauge down the side of handle. Supposed to be a clip in there somewhere. Will try that tomorrow see what happens.
Old Mar 29, 2011 | 08:55 PM
Leem's Avatar
Yes, slip a gauge down the side and it should release a clip. That's what I had to do on mine.
Marty
Old Mar 30, 2011 | 02:54 AM
mr340's Avatar
That little tab sticking out of the left side of the mount is the spring clip, the feeler gauge should work well, I have always just used the push/pull method without any issues (some are more stubborn than others)
Old Mar 30, 2011 | 12:27 PM
I took the whole thing out...made it a lot easier to pull motor and tranny
I labeled the linkages Left, Right and Center before removing them...I took lots of pictures underneath so that I could come back to them and not be a big dummy when putting it back together...I can take another pic...tonight that will show you what bolt to take out
Old Mar 30, 2011 | 12:34 PM
You're making this way way waaayyyyyy to much of a head banger. You've already made "the step" but you almost can NOT get that put together wrong.
Don't you have a shop manual? See here: Download one fer free:
http://www.forabodiesonly.com/mopar/...al%2C+download
Only difference between the picture below and yours is that yours is an overdrive. 3/4 gear (front) lever is upside down in the OD application
Old Mar 30, 2011 | 01:18 PM
Nope you are wrong...look at my shifter and look at the one in your picture..they are not the same..also people do stuff their own way sometimes...I do have a manual to.
Old Mar 30, 2011 | 03:52 PM
Thanks for the pictures. I got the shift handle out in next day or so will remove the shift handle assembly will most definitely label the rods. Just waiting for someone to be around while I crawl underneath the car.
Old Mar 30, 2011 | 04:59 PM
Listen, I'm not talking to you, I'm talking to the guy who asked the question. The picture I posted WORKS EXACTLY THE SAME AS ANY OTHER Mopar A833 shifter except for the OD which has the front lever upside down. The pictures you posted is an OD unit.
The linkage may have minor differences over the years but it works exactly the same.
Old Apr 1, 2011 | 12:54 PM
Will removed the shift assembly no big deal. Just didn't know how that shift handle came out. Now on to the fun part pulling trans. and engine out.
Old Apr 1, 2011 | 03:29 PM
I got a picture for that too..
rabys
Sep 5, 2008 09:59 PM
gotdust
Jul 26, 2008 10:15 AM
chargeruk
Sep 22, 2007 06:05 PM
Popeye
Jan 5, 2007 07:45 PM
Popeye
Dec 16, 2006 03:24 PM
