My Weekend
Old Mar 24, 2009 | 07:44 AM
Polaradude's Avatar
Sounds like your water pump seized, if the belt/s are off can you turn it by hand ? ( the water pump pulley )
Old Mar 26, 2009 | 11:01 PM
rr69half6bbl's Avatar
watch for antifreeze leaking around the base of the head now, the 2.2 and 2.5`s are notorious for blowing a head gasket when they overheat too many times. youll smell antifreeze burning from your exhaust first then itll start to sputter when you accelerate, that means the antifreeze is getting into the cylinder, if you take the plugs out and theyre wet and smell like ant-frzz. then you know whats up.hopefully it ddnt get that hot.
Old Mar 27, 2009 | 03:39 AM
Polaradude's Avatar
Or the dreaded chocolate milk on the dip stick...cringe
MReeves
Aug 4, 2009 01:30 PM
Crazy4Carz.Com
May 7, 2009 05:43 PM
NMCA Jeff
shopHEMI.com NMCA's LATE MODEL HEMI SHOOTOUT - 5-7 JUNE 2009
Apr 21, 2009 11:59 AM
BuckNeccid
Mar 9, 2009 06:20 PM
Doc
Nov 7, 2008 08:07 PM
