NEED HELP '91 Daytona Engine Swap im trying to do
Old Jan 24, 2009 | 04:36 PM
Daytona45's Avatar
Junior Member
Question NEED HELP '91 Daytona Engine Swap im trying to do
i seriously need help i have a '91 dodge daytona it has a V6 SOHC engine in it now but that has almost 200,000 miles on it...so i am just trying to figure out what engine i could put in there that would not need any body remolding well basically that just wouldnt cost too much to do the swap
Old Jan 24, 2009 | 07:50 PM
Daytona45's Avatar
Junior Member
but which V6 would i be able to put in there? my uncle is a mechanic and he said that the 6G72 DOHC engine wouldnt fit i just dont know of any engine that would fit in there. to tell you the truth it could even be japanese i just want an engine i cant do work to.
Old Jan 25, 2009 | 03:06 AM
rr69half6bbl's Avatar
Hi daytona, You can use a 3.0 ltr. v-6 from any dodge 88- 93. theyre a dual o.h.c. setup . they arent super fast but you can get performance parts for them. they use the same trans to bell pattern. you only need to change the oil pan to the 1 you have on your tona. most of the 3.0`s in that time froma made around 190 horse. the newer the motor also the bigger the throttle bodies gona be. Im pretty sure.
Old Jan 25, 2009 | 03:50 PM
Daytona45's Avatar
Junior Member
thank yall im not tryn to put a v8 in the car jus because im on a limited budget....and my uncle said that the DOHC 6g72 engines will not fit in my daytona
Old Jan 25, 2009 | 06:22 PM
Daytona45's Avatar
Junior Member
also is there anytype of four cylinder engine that i could put in there? plz let me know any advice is helpful but i am going for more of a street car not so much a racecar
Old Jan 25, 2009 | 07:13 PM
whats wrong with the current engine?
Old Jan 25, 2009 | 08:47 PM
challenger's Avatar
the best thing is to just take the one you have and rebuild it , i have a 92 stealth that im rebuilding and the only hard part is patients as you will be getting some nuckle busters on this one
Old Jan 26, 2009 | 07:13 AM
Daytona45's Avatar
Junior Member
yea the current engine is nice and i could have it rebuilt easily but they make no after market parts for the 12V SOHC engine and the valves are known to bend or even break under alot of pressure and stress aftermarket parts have been put on it. but i am still considering that. i love the way the 12V sounds like a small V8 but is there anyway i could put the top end of the DOHC onto the bottom end of my current engine?...like i said all advice is helpful and thank you all
Old Jan 26, 2009 | 01:57 PM
challenger's Avatar
as far as swapping heads im sure you cant and with the aftermarket parts i would check e-bay first as they have alot of stuff on there for your engine and when you bend a valve it is usually do to the timing belt skipping or breaking so i recomend changing it every 60,000 miles and you should never have to worry about them getting slaped by the pistons . also try not to miss a gear as that can sometimes let them touch also do to the short throw on the valves with the stubby lifters ,.,.,. I would just rebuild the one you have and enjoy it for another 200,000 thousand miles, if you have any questions just ask and o ya when you change out your timing belt always be sure to change out the water pump !!!!! ok
Old Jan 28, 2009 | 08:22 PM
Daytona45's Avatar
Junior Member
can someone plz give me a deffininte answer as to whether i can or cannot put a stealth motor (DOHC 24V 6G72) into my 1991 dodge daytona which has the SOHC 12V 6G72 in it already...Thank you alllll
Old Jan 29, 2009 | 05:35 AM
Daytona45's Avatar
Junior Member
thank you i have plenty of time as i still have to draw money out of my CD and that can actually take up to a month lol. But i was lookin at the SOHC and DOHC application on the same year stealth as my daytona and everything on the stealths is in exactly the same place on both the SOHC and DOHC versions and they both have the same locations for the battery, trans fluid, intake, and many other things as my daytona does...but thank you so much hope to talk to ya soon
Old Jan 29, 2009 | 05:28 PM
challenger's Avatar
ill say no more ................ Dave Black's 3000GT/Stealth Resource
Team3S- Dodge Stealth & Mitsubishi 3000GT Owners' Pages just go here to one of these sites if your going to do anything to your stealth
Old Jan 29, 2009 | 05:32 PM
challenger's Avatar
sorry your daytona but these sites have all you need to no about the dohc engine out of the stealths if you are trying to make a swap , they might be able to help you out the best
Old Jan 30, 2009 | 07:28 PM
Daytona45's Avatar
Junior Member
i couldnt find anything about an engine swap on either of those sites
Old Jan 31, 2009 | 04:32 PM
Daytona45's Avatar
Junior Member
its a 3.0L SOHC 12v my intake manifold is a lil bit different than even the stealths 3.0L SOHC 12v which is the same motor
Old Feb 12, 2009 | 06:05 AM
Daytona45's Avatar
Junior Member
can anyone just please tell me what engine to drop in? i would like a 6g72 DOHC 24v but if its not possible then i just need to know what engine i can drop in there that has some good potential.....any help is greatly apreciated
Old Feb 12, 2009 | 06:51 AM
johnthegoalie's Avatar
thinkin with me dipstick
anythings possible with one of these...
i'm partial to this...
Old Feb 19, 2009 | 11:07 AM
challenger's Avatar
YOU CAN NOT put a 6g72 in your daytona the 6g is a mitsubishi engine and will not bolt up to your trans that is why i told you to check out them sites , unless your sov engine says mitsubishi on it it will not work so if you want an enginge to put in then rebuild the one you have or call a car yard and get another one the same and put in there or ask them to cross ref: it for you as they should have the books to tell you ( all ohc engines slap valves to pistons if your timing belt looses a tooth as they are >0< clearance engines
What does your engine say on the motor does it say MITSUBISHI or not , i do not have a book on the daytona so you will have to tell us some #s that are on your engine if you want
Old Mar 16, 2009 | 09:14 AM
  #24
Daytona45's Avatar
Junior Member
my motor is a 6G72 but it says chrysler on it but i know for a fact that it is a mitsubishi block chrysler jus built all the externals intake manifold/ exhaust etc
Shannon
Mar 3, 2013 08:19 PM
Shannon
Mar 2, 2013 01:27 PM
scamp1975
Jul 20, 2011 03:03 PM
Daytona45
Jan 24, 2009 04:18 PM
