No Cruise Control After Engine Repair
Old Oct 17, 2014 | 03:21 PM
mexbungalows's Avatar
VEHICLE: 1995 Dodge Spirit 3.0 V6 Engine
Symptoms: Cruise Control playing possum
Was working fine before timing belt, water pump replacement.
Fuse in fuse panel is alive both sides
Checked hose connections at servo. All are connected.
No check engine lamp light. ECU is not in open loop
Is there are troubleshooting guide for this? The factory manual is a little weak in this area. The car is worth fixing.
Thanks in advance
Old Oct 17, 2014 | 06:56 PM
moparted's Avatar
does the speedometer work?
Old Oct 18, 2014 | 02:52 AM
Speedometer continues to work perfectly. Does the brake light switch have a separate circuit for cruise control disengagement? I live in Mexico.
Old Oct 18, 2014 | 02:05 PM
pro-tech's Avatar
Check all vacuum lines the cruise gets it vacuum from the fitting by the brake booster.. Also check for cracked hoses and electrical connections...Bill
Old Oct 19, 2014 | 06:00 PM
Did that. Sure wish there was a troubleshooting step-by-step guide in the factory manual.
Abnormal
Jun 2, 2014 01:11 PM
68plymouth383
Dec 6, 2013 07:35 AM
dnlwstwd
Oct 12, 2011 08:08 AM
Moparknighthawk
Sep 22, 2008 08:11 PM
Mopar Guy in Delaware
Apr 7, 2008 10:52 PM
