Oil pan pickup problem again
2 Attachment(s)
I have a Mopar performance 8qt pan p5007816. I just got my oil pickup in today Mopar Performance p5007817. The pickup is wrong it hits my rods.. Did somebody swap out the pickups in the box. Or did I order the wrong item.
Here are two pics, what does the 8qt 3/8 thread pickup look like. I know the half is the square one. |
It should look like number two.
The one I got looks like #2, jegs and a couple other sites show a pic of the round looking factory one being a 3/8 thread 8qt pickup. Am I missing something, I am screwing it in the block were the stock one came out. This has really became a pain in the rear, I thought by useing Mopar Performance parts I would be cutting out the BS of fabbing and head scratching.
Is the pick up parallel with the block ? Can you bend it a little ? Is it a stroker motor ? any pictures ?
Stock stroke the tray fits fine, give me 10 min I will get you a pic.
3 Attachment(s)
The factory windage tray clears fine
Thats way more than a little bit,aint it! So if you bend it out of the way...Will the pan still fit? Or is the pickup just wrong?
Originally Posted by bigblock
(Post 98291)
I would have to say it is bent wrong from the factory
Talked to a guy that builds a lot of race mopars and he said that was the correct part number. Also called Mancini and they said the same thing. So I ordered another one from Mancini. I guses in a few days we will see what happens.
The problem with Mopar Performance parts these days is that they can even be made in China.
(Post 98328)
Mopar crate motors are also kick A--.. And Mike at mrlperformance.com builds whatever you want and is always willing to answer any performance question you may have. He is also on the sister site of this forum. Mopar & muscle car tech forums:yikes:
seems like the only thing our country manufactures today is over weight people.
And weapons! |
I hear that. Everywhere you look it is made in China. They own this country. Its called outsourcing.. I call it Bullsh-t.
Originally Posted by pro-tech
(Post 98419)
Its Obama care.
i keep hearing the rumors... Civil war.
The defense dept asked the generals if they would have a problem with shooting american citizens if they said yes they were let go. I cant remember where I read or heard that. But I kinda believe it with all the BS over gun control.
1 Attachment(s)
Got another Mopar Performance pickup in from Mancini, it still was not correct but closer. It was 1 1/2 inches off the bottom of the pan and still hit the tray. I did get it bent correct and got it to work after taking it on and off about 10 times.. I will never buy another Mopar Performance pan or pickup again. JUNK..
Before pic before I altered it. |
Was it actually 1 1/2" off the bottom ??? IT should be about 3/8" I wonder if a short extension from pluming dept would work
Yah 1.5 off the bottom and it still hit the rods, I got it all worked out, took some of the bend out of it. It just pissed me off buying the correct pan and pickup and they do not fit correct. If I have not been farting around with this pickup problem for 3 weeks I would have sent all of it back and got a Milodon set up.
