davegb |
02-26-2011 09:28 PM |
Please someone give me a hand!
So here is the deal. I have a 2003 Pt cruiser turbo/ SRT4. When I turn on the defrost the idle drops to about 700 rpms. When I’m on the highway and need to get up to speed I get a bogging then it picks back up to speed.
So after several hours of research I started replacing parts. Here is the list of parts I have replaced. Fuel pump, NGK iridium spark plugs gaped at .50, camshaft sensor. IAC motor, throttle body sensor, engine temp sensor, coil, spark plug wires, had the injector tested they all had good flow and spray pattern. Timing belt, upper and lower o2 sensor. It’s not bad gas I use chevron gas only never cheap AM/PM gas.
I could really use some insight on where to look next or a good shop that knows their ass from the hole in the ground that could give a hand. I leave in the Seattle/Redmond area and willing to drive to the place of business.
