should i buy the hemi peply quickly plz!!
Old Jun 6, 2009 | 06:32 PM
theomahamoparguy's Avatar
Is it in a '55 or '56 Chrysler?
Do the plug wires enter the top of the valve covers or go into cover that goes down the center of the valve cover?
Old Jun 6, 2009 | 06:42 PM
Crazy4Carz.Com's Avatar
The early hemis had the distributor in the back the later ones in the front on an angle. Like Omahaguy said the plug wires go right through the valve cover, and sadly these motors never had "*****". but they look great in a vintage hotrod.
Old Jun 6, 2009 | 06:47 PM
But I think of all the early style Hemi's, the 354 is the best. Alot tougher than the 392 and supposedly the heads flowed a little better.
Old Jun 6, 2009 | 06:51 PM
It all depends what you want to do with it. Sure it is not a 2nd or 3rd gen. type of hemi but it still has some potential. Liker if you wanted to build a replica of an old Gasser or something like that. You know that would look real cool in an old ****** or an old studebaker. Especially with an 8-71 stickin outta the hood.
Old Jun 6, 2009 | 07:09 PM
well Im sure anythings possible but what is practicle. I'm not sure how much it would cost to make a 354 into a pavement melter. For practical purposes, you could just find a 400 big block and do just as good, you know with a stroker crank and some aluminum heads and a roller cam, etc. It would be alot cheaper I'll bet. Now if you just want looks and some decent performance, I guess the 354 would be OK. The best part of the 354 would be in the looks department, nothing quite looks like an old style Hemi. But note one thing though, they are EXTREMELY heavy.
Old Jun 6, 2009 | 07:41 PM
weren't you gonna do the new hemi swap?
Old Jun 6, 2009 | 09:14 PM
Originally Posted by 1973charger
so im better off waiting for a different hemi then? this is the cheapest i have found and nobody wants to come off the prices i mean 10000 for a 429?? are you for real??!!
429 CI motors are a F$#d, not Mopar.
Old Jun 6, 2009 | 09:26 PM
scotts74birds's Avatar
X2 bro
Old Jun 6, 2009 | 10:33 PM
johnthegoalie's Avatar
thinkin with me dipstick
"should i buy the hemi" is like asking, should i get with the hot blond with big *****?
Old Jun 6, 2009 | 10:46 PM
End of the day......A354 hemi is cool and would look good in a street rod, and I'd try to sell it to one. But parts are expensive and not very available. There are cheaper, and faster ways to go for a 70s muscle ride.
Old Jun 7, 2009 | 05:45 AM
You need to sit down and figure out what you exactly want out of this car. Do you want it to for cruising, for shows, to go fast on the strip. a mix and match of everything. Once you figure that out, then let us know and we can better help you from there.
As far as a 354 Hemi goes, I'd only put it into a hot rod or 3/5 window coupe. That is a beautiful motor to show off when built and detailed right.
Old Jun 7, 2009 | 06:17 AM
X2
Old Jun 7, 2009 | 07:03 AM
BuckNeccid's Avatar
A 354 should have the 54 on a pad on the front of the block, pretty close to where it is on a 440. If it's not there, take the numbers off the pad, check with Hot Heads, they will be able to identify what it is for sure.
The valve covers should say Chrysler FirePower on them, anything else and it's possibly a Dodge or Desoto version, avoid them.
We have a 354 in a 56 Ford Pickup, it's strong, but not a monster, has a great sound, tremendous WOW factor and loads of torque. It's driven pretty often, and has been on cruises of 3-400 miles with pretty good reliability. Parts are available from Hot Heads, and a few other places, but don't expect to go to like Advance and get most of what you need. It was rebuilt 3 years ago, for the first time in over 30 years.
Old Jun 8, 2009 | 07:34 AM
BuckNeccid's Avatar
Thankee Sir, we like it
Old Jul 9, 2009 | 05:20 PM
look at headmen headers
Old Jul 9, 2009 | 05:51 PM
  #24
I heard TTi makes the best fitting ones. Mine came with heddmens. Real tight on some of the plugs. Same thing as you, 383 in a 73-74 b-body
furyaboveall
May 6, 2011 01:46 AM
72Dartman
May 10, 2010 01:59 PM
ryguy
Mar 18, 2010 04:06 PM
pbpunisher
Nov 26, 2008 04:09 AM
mcarmaniac
Mar 22, 2008 11:59 PM
