Stalled
Stalled
I was going to test drive my 65 coronet down the road today when I was pulling out of the driveway and the car stalled and wont start again. I pulled a plug and it was wet. Could the plugs have fouled out because their the old plugs from when I had the bad carb in and flooded it real bad. help please
Guest
Posts: n/a
I would pull all the plugs and dry them out. Measure the gap while you are at it.
Because it was already running it sounds like there is something else going on. How long before you last drove the car? How old is the gas? What kind of carb?
Please advise and let's see if we can help you.
it has new gas in it. I drove the car last night and it was fine. Now i went out this morning and it started right up and I went like 20ft in my driveway and it stalled. I tried to start it but it wouldnt start. I pulled a plug and it was wet like it wasnt getting spark. Could the plugs just have fould out because their old or could it be something else in the ignition? I put on a new distributor cap and rotor also.
sgp check your choke and make sure its not staying closed and cant remember but do you live where its cold or warm and again i would check to see if your plugs are even fireing and go from there as it could just be a flooding issue from your floats sticking or not set right
Guest
Posts: n/a
Guest
Posts: n/a
Guest
Posts: n/a
What is the idle speed?
MM
