Stalled
Old Jan 1, 2009 | 09:00 AM
sgp7679's Avatar
Question Stalled
I was going to test drive my 65 coronet down the road today when I was pulling out of the driveway and the car stalled and wont start again. I pulled a plug and it was wet. Could the plugs have fouled out because their the old plugs from when I had the bad carb in and flooded it real bad. help please
Old Jan 1, 2009 | 09:41 AM
sgp7679's Avatar
it has new gas in it. I drove the car last night and it was fine. Now i went out this morning and it started right up and I went like 20ft in my driveway and it stalled. I tried to start it but it wouldnt start. I pulled a plug and it was wet like it wasnt getting spark. Could the plugs just have fould out because their old or could it be something else in the ignition? I put on a new distributor cap and rotor also.
Old Jan 1, 2009 | 11:12 AM
challenger's Avatar
sgp check your choke and make sure its not staying closed and cant remember but do you live where its cold or warm and again i would check to see if your plugs are even fireing and go from there as it could just be a flooding issue from your floats sticking or not set right
Old Jan 1, 2009 | 11:21 AM
i think his engine is the 318 with a one-barrell carb
Old Jan 1, 2009 | 12:21 PM
Commando's Avatar
They had one barrels through the 80's.
Old Jan 1, 2009 | 03:02 PM
sgp7679's Avatar
I have a 318 with a carter 2 barrell carb. I checked and its getting spark but the plugs look pretty fouled. Could fouled plugs cause that car to stall then not start?
Old Jan 1, 2009 | 05:59 PM
Commando's Avatar
Originally Posted by 69 Mopar Maniac
Give me an example of a Carter one barrel.
I do not know about a Carter one barrel, but there were one barrel carbs. The L6s used them for one example an 83 Cordoba with the L6 225ci 3.7L.
Old Jan 2, 2009 | 02:26 PM
sgp7679's Avatar
I figured out what happened. The points went out. I ordered a pertronix electrical conversion kit today. has anybody tried the kit before?
