TCI Outlaw Shifter
Old Jul 10, 2011 | 09:25 PM
Mr. Belvedere II's Avatar
TCI Outlaw Shifter
I recently purchased a 1966 belvedere II with a 440 and a 727 trans.The car had a TCI Outlaw shifter installed by the previous owner. If I adjust the cable to reach 1st and 2nd I can't get park. If i adjust it to reach park i can't 1st and 2nd. Does anyone have experience with this setup? I didn't get any extra shifter parts from the previous owner. I think the remedy might be TCI #890-148500
Pan Bracket and Level Kit for Torqueflite 727/904. But I'm not sure. Should the factory shifter lever on the trans work ?? Am I just adjusting it wrong? The shifter has the correct 3spd forward gate plate on it and the trans makes positive engagement in each gear when I move the trans through the gears by hand.It seems like the cable does not have a long enough throw. Any help would be great. Thanks.
Old Jul 10, 2011 | 10:39 PM
It might be a reverse pattern shifter or ratcheting ?? Are you ratching the shifter when changing gears?? Put it in drive release the shifter, then pull back to 2th- release the shifter pull back to low.
Adjust it for park position
Old Jul 11, 2011 | 07:55 PM
It is a ratcheting shifter, but it's not a reverse valve body.The ratcheting mechanism doesn't seem to be interfering with the shifter operation. I'll have to call the guys at TCI again.
Old Jul 11, 2011 | 09:50 PM
Cazbah362's Avatar
Instrcutions
Mr. B,
OK, Had the same problem with my B&M Pro Stick when I changed out my cable. I was up at Summit Racing and I walked by the cable and noticed the instructions on the front, so I took a picture. I follwed them and it fixed my issue.
Very Nice car, really like it -- love your hood, I am in the process of putting GTX scoops on mine -
Hope this helps
Old Jul 12, 2011 | 12:05 AM
If the shifter cable runs forward around the starter ? Put some heat shielding around the shifter cable
Old Jul 12, 2011 | 05:12 PM
Thanks Cazbah, I think i just need to fine tune the cable bracket and swivel position. Hopefully I'll be able to make it work. Thanks for the input guys.
dartsport340
Jul 23, 2010 05:06 PM
rabys
Sep 5, 2008 09:59 PM
chargeruk
Sep 22, 2007 06:05 PM
Popeye
Jan 5, 2007 07:45 PM
Popeye
Dec 16, 2006 03:24 PM
