Mopar Forums (/forums/)
-   General Discussion (https://moparforums.com/forums/f62/)
-   -   Torque Converter question (https://moparforums.com/forums/f62/torque-converter-question-6317/)
smackhonda May 25, 2010 08:07 PM
I have a nice torque converter that I had made for my 360 small block. Since the 360 is externally balanced it has the weights on it. Im converting my car to a 5.7 hemi now and was wondering if I could take the weights off the torque converter and used it with the 5.7. Im using my same 727 trans and have a flex plate made for the 727.
440truck May 25, 2010 10:10 PM
as long as you can remove the weight without damaging the converter it shouldn't be a problem
1966sportfury May 26, 2010 04:36 PM
is the 5.7 internally ballanced? if so i agree with 440truck.. or should i say ls1 truck, its not hard pulling a weight off.
smackhonda May 26, 2010 07:17 PM
thanks guys, this will save some money. Im sure the 5.7 is internally balanced but il double check
