Transmission leak
I went out today and looked under my 65' coronet and saw transmission fluid on the ground. I haven't driven it in a few weeks and when it was parked the transmission wasnt leaking. It just started leaking this morning. What could cause it to leak?
Alot of times they start leaking form sitting to long.if i were you i would replace the gasket/filter and if it is an older tranny i would reuse the tranny fluid you took out of it.Hope that works for you.We were in florida for three month and when we got home the same problem with my Plymouth.Hope that helps you
"what would cause it to leak?"
That is what i am talking about. Too much time on line and not enough under the car. Heck JUST LOOK UNDER THE CAR!!!!!
Guest
Posts: n/a
I recently fixed a problem like this. Had a cheap chrome trans pan made from china or something that I installed. Sure it looked good, but man it leaked like hell. A guy that new abit more about this type of stuff said the cheap chrome plated crap made oversea's always leaked. Went with an aluminum pan with a deeper sump and never had any problems after that.
demetri
Feb 26, 2014 07:32 PM
jerzjer
Apr 29, 2011 03:02 PM
