Vacuum Readings
Old Jul 10, 2010 | 06:07 PM
Barfly's Avatar
Vacuum Readings
'72 340
I'm going to research this as well but there is nothing like real life experience so I will throw this out there for you guys thoughts.
I just bought a vacuum gauge, as vacuum seems to be a big part of tuning in the engine, so I have read.
@ a warm idle of 650 rpm I'm showing 18 Hg of vacuum. No other reading have been taken yet.
Good, Bad or Ugly
Thank you
Joe.
Old Jul 10, 2010 | 06:11 PM
1966sportfury's Avatar
A.K.A Bob Dodge
that quite of bit of vacuum, doesnt have a huge cam in it, bigger the cam the less vacuum you will get,
Old Jul 10, 2010 | 06:45 PM
scotts74birds's Avatar
Here ya go buddy!
http://www.visn2.com/UsingVacumeGauge.html
http://www.secondchancegarage.com/public/186.cfm
Old Jul 10, 2010 | 06:48 PM
Archer's Avatar
Joe -
For a modified engine that's pretty high. Even a cam with a mild lope (overlap) can knock down your vacuum. I get about 10mm with a flicker in gear (700 rpm) and about 15mm at idle (900 rpm).
Old Jul 10, 2010 | 07:40 PM
Barfly's Avatar
Wow guys, thanks for the info.
Looks like I don't have any more than a stock cam.
And the idle test I did earlier looks as if the the vacuum
is exactly what is expected form a well tuned stock motor
(15 - 22 in.) I measured 18 in. and steady as a rock.
I get her all mounted up in or below the dash tomorrow and see what she looks like traveling down the road.
Thanks again, great info!!!
Joe.
Old Jul 11, 2010 | 02:37 PM
a steady 18 is very good
Old Jul 11, 2010 | 04:21 PM
blue 68 gts's Avatar
Anywhere between 18-22 or hg of vac is good and normal
Old Jul 11, 2010 | 07:17 PM
Barfly's Avatar
Thank you all for your input.
Here is a pic of the gauge in use.
Kevin71
Jun 3, 2015 09:04 AM
champer
Sep 3, 2014 02:43 PM
66coronetgirlie
Aug 9, 2010 10:41 PM
340CUDA
Mar 16, 2009 05:27 PM
burnsy26
Oct 1, 2007 01:35 PM
