VIN on '72 Satellite
Hi I am trying to start finding some information on my 1972 Plymouth Satellite. I think the right place to start would be trying to break down the VIN number. Does anyone have any info on how I can do that? Thanks
The vin has some info that will verify the motor and where the car was built. For any real info, you need to decode the fender tag on the inside of the drivers fender. And yes, some folks here can tell you everything about it. I can help you with the first 7 digits of the vin, but I dont have the codes for all the options.
OK thanks the VIN is RH23M2G107847. I'll look up the fender tag first thing tomorrow.
R = Plymouth Belvedere/Satellite
H = High 23 = 2 Door Hardtop M = 400 190HP(net) 1-2BBL 8 CYL 2 = 1972 G = St. Louis, MO, USA 107847 = 7846th Vehicle Post up a pic of the fender tag and it can also be decoded for you. |
Exactly:D
fender tag
1 Attachment(s)
I think this is it. Hard to tell because it has been painted.
R11 V5X END GY8 U G35 J52 M21 M33 GY8 F1Y3 GY8 812 135091 E63 D34 RH23 M2G 107847 |
Here ya go...
RH23: Plymouth Belvedere,Satellite High 2 Door Hardtop M2G: 400 190HP(net) 1-2BBL 8 CYL 1972 St. Louis, MO, USA 107847: Sequence number E63: 383 cid 4 barrel V8 H.P. 335hp D34: Light Duty Automatic Transmission GY8: Gold Poly Exterior Color F1Y3: Trim - Luxury, Unknown, Gold GY8: Gold Poly Int. Door Frames 812: Build Date: August 12 135091: Order number GY8: Gold Poly Top Color U: USA Specifications G35: Delete Standard Outside Mirror J52: Inside Hood Release M21: Roof drip rail moldings M33: Body Side Moldings R11: Radio Solid State AM (2 Watts) V5X: Body Side Stripes, Black END: End of Sales Codes |
Thank you very much!!!
dude, thats sounds like a very nice car. and a big block too. man you can put a 440 right down onto that bad boy, with noe mods. awsome. or build the 400 very nicely.
2 Attachment(s)
Yes it is a very nice car but as you can see the previous owner repainted it and tried to make it into a roadrunner. It also has a 4 barrel instead of a 2 on it. Needs a little work to be a daily driver and can't wait to take it to school.
Needs a rear wing!:D Then again, everything needs a rear wing! I'm stuck in the 70's.
And maybe some roadrunner emblems also a beep beep horn.
(Post 30699)
Originally Posted by 72RDRNR
(Post 30757)
Might as well put some big ol' meats out back, that would complete the Scotty look.
Dont forget the air-shocks for the improved mileage cause you're always going downhill!:D Nothin wrong with the "period correct" look. Some aluminum slots and Mickey Thompson 50's stickin out the sides would tie it together! My current bike project is a 53 custom rigid harley frame, raked with 6+ inches in the front forks and 18" apes and a 73 Shovelhead with a kick-only tranny. The goal is no flash and no billet, only what was available in 73 for a chopper. Like I said, period-correct.
(Post 30768)
yer rite! I left that out, you MUST have fender damage to the tires cause they are too big!
