wat is under my hood?
Old Jul 15, 2009 | 09:21 PM
fury_19's Avatar
Question wat is under my hood?
ok guys i have always assumed i had a 318 in my fury but now im not sure..... i was talkin to a guy about the diff between a 318 and a 318 magnum and he showed ne the easy way to tell the difference was the number of bolts that hold the valve cover on... 5 for a normal and 10 for the mag... but mine only has 2... so wat is it? i have pics on my album it has a rear dist so its not a big block.... wat could it be?
Old Jul 15, 2009 | 10:05 PM
theomahamoparguy's Avatar
You have a polysphere 318 {i have not looked at the album}
they have two bolts holding the valve cover down. Last year was 1966 for the "poly".
Old Jul 15, 2009 | 10:11 PM
64fury's Avatar
Hmmm! always thought the 318 had a 5 bolt valve cover and the 318 poly had 2 bolts in the center of the valve cover! Your pic shows 2 bolts, so i would assume you have a 318 Poly!
Old Jul 15, 2009 | 10:13 PM
fury_19's Avatar
ok so wat else do you kno about the polys? is this a good or bad thing?
Old Jul 15, 2009 | 10:17 PM
alot of the parts interchange between the Polysphere and the LA 318 {means later A engine}. Has the same bellhousing for the transmission {so you can bolt up a "newer" 318 to your trans} the distributor will swap, the crankshaft will swap {poly cranks were forged!!} The timing cover and water pump should swap. the motor mounts will swap. the rods (90% sure) and the carburetor will swap. Or you can keep the poly and upgrade it if you like. You can still get parts for them.
Old Jul 15, 2009 | 10:19 PM
64fury's Avatar
Weren't the 66' poly's rated as a 317? or was that the 56'?
Old Jul 15, 2009 | 10:22 PM
fury_19's Avatar
well the guy has a set of heads for a L-a 318 and a Mag but coulld i turn my poly into a mag?
Old Jul 15, 2009 | 10:23 PM
fury_19's Avatar
according to the green book its 318
Old Jul 15, 2009 | 10:39 PM
No, the LA heads will not bolt up to the Poly block according to everything that I have read.
Old Jul 15, 2009 | 10:41 PM
Note: I have never personally tried to bolt LA heads to a poly block. I've just heard that it cant be done.
fury_19's Avatar
just my luck...so i bassically have a ***** block in my car and no hope to build it out huh?
Old Jul 16, 2009 | 08:18 AM
bigsho's Avatar
i have a buddy that has a '64 fury with the 318 poly. he built it up quite well..its pretty damned mean. if i remember right...he had his heads reworked at a local machine shop. the hardest part was the cam...think he had to have one made...and he had a hard time finding an intake manifold for it. took him a bit to get all the pieces together and cost him a pretty penny but in the end its a screamer
Old Jul 16, 2009 | 08:31 AM
fury_19's Avatar
Cool
well im for cheap and fast lol... that was the whole muscle car theme right? but i was just hoping to rebuild it for later use or maybe for a project 4x4... ill just swap it for a LA cuz i really want to build a MAG now
Old Jul 16, 2009 | 08:43 AM
pjmopar's Avatar
Hi , i have a 318 poly in my Plymouth and i think it is a very good engine.This is a web site ,Diamondback Engines .There are other websites for the poly.I was on a site the other day and they can get 500 hp out of these engines fairly easy .Good luck
Old Jul 16, 2009 | 12:55 PM
fury_19's Avatar
thanks for the forward on diamondback yeah they arent to far from here so ill work with them on the rebuild wen i get to that part... for now i gotta get my 440 and start workin on it
Old Jul 16, 2009 | 04:33 PM
the poly was discontinued because it got terrible gas mileage, and it wasnt much more powerful than the regular 318
Old Jul 16, 2009 | 07:55 PM
fury_19's Avatar
isnt it almost like a hemi tho?
Old Jul 17, 2009 | 08:40 PM
kind of
it a polyshperical head
think of it as a semi-hemi
it didnt require the dual rocker shafts
the combustion chamber was round, but the plugs went in from the side
MOPAR TIM
Jul 28, 2014 07:22 PM
slpolson
Mar 19, 2014 02:29 PM
Mr. Belvedere II
May 23, 2012 05:31 AM
envyedrico
Jan 19, 2010 01:42 PM
vitaminc383
Jul 19, 2008 09:11 PM
