What spring.radiator hose.
Good day all.
So check it out i decided to replace my lower radiator hose....thinking its the issue with a hot running motor. Especially when a/c running. Now. i feel this is the reason because there is no spring in the hose. And its collapsing restricting flow. With all that being typed. The new replacement has NO. spring....unless i purchas the flex hose....which by the way is way more solid than the molded. So it was my understsnding that all lower hoses had a spring in them. Sooo. What's what? |
AS far as I know... You got it rite.... I Agree.... :)
Unless you buy a spring to install in the lower hose. Your kind of limited to to the Flex stiff hose... |
Ok good news....
Looks like that was the trick.....after she sucked All the coolant she could possibly take. She's running at 150. Its 80* 98% humidity and running at 150* with a/c. Unless my tep gauge just took a dump "i kept taping it ":smash: Seems shes getting all the circulation of coolant with that new hose with a spring. This is the first that this has happened to me. What about other's.have you gotton lower hose without a spring.? |
Freting over shit that don't matter, FOSTDM, I haven't used a lower rad hose that had a spring in years. Really!
(Post 140718)
